Nieuwe firmware Garmin 60C
GPS, (detail)kaarten enz.
De nieuwste software voor de kleuren 60C is nú beschikbaar. Gratis te downloaden vanaf: http://www.garmin.com/support/agree.jsp?id=547
Changes from 3.60 to 3.70
Fixed transfer problem with custom waypoint symbols.
Now reports DEM map support to PC software.
Fixed lockup that could happen when selecting a Tracback point.
Fixed shutdown caused by viewing some Marine Light points.
Fixed problem with Indonesian Southern Grid using wrong longitude of origin.
Add advanced NMEA support settings to support certain marine autopilot units.
Fixed problem where the interaction with certain beacon receivers was not displayed.
Added Select Map option for Address and Intersection searching.
Fixed problem where waypoint depth was not being saved as invalid when it was unknown.
Fixed problem where waypoints could not be saved in certain areas of BlueChart maps.
Fixed lockup that could occur when selecting symbols for waypoints.
Added warning message about removing batteries when Pressure Trend Recording is always on.
Fixed lockup that could occur when approaching certain roads on the map.
Added Jumpmaster support under Setup.
Made the way intermittent water areas are drawn more visible.
Fixed problem where compass pointer could transition to next turn too quickly.
Fixed problem with bearing being adjusted improperly when projecting waypoints with a non-zero north reference.
Fixed lockup that would occur when 'finding by name' and then viewing map information for the point.
Fixed problem in tide charts where local time axis would not match the station time axis.
Changed tide stations to show selected date when saved on a calendar day.
Fixed potentially sending wrong number of bytes for USB get requests
Fixed problem with displaying Waypoint At Destination while doing a tracback.
Fixed problem where route recalculation would slowly go to 100% and lockup.
Improved WAAS search and selection process to be smarter in it's handling of multiple SBAS service providers, overlapping service volumes, and exceptional conditions.
Fixed lockup that could occur when selecting a point to which to tracback.
Abbreviated long Leaving Proximity message in German.
suc6,
Scheelt vooral bij het "Trekbekken" :P (geen blokkeren meer zodat je de baterrijen er uit moet trekken om de bende te resetten.
Ook voor de GPSMAP 60 beschikbaar (versie 2.20)
