And...sh...t. Something happened and I do not know how.
Front wheel now sits in WP forks at least 2 mm to right side of the forks centerline, so 2 mm wrong offset. I have no idea how that happened, all I did is tested new rear suspension by "fly by" over some objects/bumps.
I mean - not wood logs, but just smaller things. Also I took off and put back on relatively fresh MT21 tyre I had in garage, but no extremes like standing on the wheel etc.
Now apart from wrong offset wheel also looks like egg
Guys, question I have is: by how many mm you may offset wheel using spokes tension when it comes to DR front wheel? I already seem to have managed about 1 mm but it starts to feel like something going to give.
On 17" wheel it is easy to manipulate offset about 4 mm range, but on 21 it seems a bit extreme
