Digital jetting
Digital Jetting
December 17th, 2008
As many of you know 2009 is the year that most of the Japanese manufacturers have released fuel injected four-stroke dirt bikes. There is no doubt that the carburetor has worked well over many decades but fuel injection has the ability to address the main shortcoming of the carburetor. That shortcoming is the ability to function over a wide range of elevations without needed to make adjustment. Last year we had a racer enter the Pike’s Peak Hill Climb where there is an elevation change of over 7400 feet from the base to the top of the mountain. With a carburetor there was no way to make the bike run great at the bottom and the top of the course. While many people will never experience this type of elevation change during a ride, many of our customers do ride in the mountains where there is enough of an elevation change to make drivability a concern.
While fuel injection delivers great performance at any elevation straight out of the box, just like a carburetor there is room for improvement. Bikes come from the factory with programming in the control module that is often designed for engine longevity, EPA requirements, or to cover a wide range of styles. Carburetors used to come tuned the same way and we have seen a whole industry devoted to improve their operation. With the switch to fuel injection this industry is not going away, it just evolving. No longer are we going to change jets and shim needles, but instead we are going to be hooking up a laptop and logging data and downloading changes to the control modules on the bikes.
At OTD Denver we have always been on the forefront of carburetor tuning. Especially with regard to four-stroke single cylinder dirt bikes. While the tools, equipment and methods have changed our commitment has not. We have already begun our fuel injection tuning program by offering customized maps for the 2009 Honda CRF-450R. With our map for max power we are producing about three horsepower over stock and made the bike easier to start. Some other customers have requested that we make the power mellower for trail riding are we are able to do that as well. These maps are offered at affordable prices and we are willing to work with you until we get the results you desire. If you have a programmer we can e-mail maps. If not we offer same day turnaround on all ECM sent to us. Additionally, once Dynojet releases their Powercommander 5 we will be offering sales and mapping for those as well. This is something we are very excited about and we encourage you to ask any questions. If you do have questions please e-mail us at tuning@otdcyclesports.com .
-Jonathan Fisher
Service Manager OTD Denver
De PowerCommander V's zijn in NL waarschijnlijk goedkoper, maar Eddie Sisneros levert life time gratis en op verzoek nieuwe mapping bestanden zolang als het apparaat in jouw bezit is. Kost $350 incl. nieuwe map.
Alternatief is de EFI zelf te overschrijven en wat PC software te kopen:
http://www.probike.co.uk/downloads/bike ... ctions.pdf
speedphreax
Ach ja, Erwin's oeroude wet van behoud van ellende: Alles kan altijd een stuk beter en als er in een bepaald gebied iets verbeterd dan kun je op een andere plek weer net zo hard aan het verbeteren slaan...
Dacht jij dat dat voor een injectie niet op ging dan?
Voor een crosser mag je verwachten dat je A/F ratio optimaal staat. Voor een injectie-enduro mag je verwachten dat ze er aan gesleuteld hebben tbv de emissieeisen. Ik moet nog uitzoeken of dat bij die van mij zo is. Eerst even lekker inrijden...
mouser
Inrijden?? Wat is dat? Nieuwe machine warm draaien, en daarna wisselend belasten. Vollast, deellast, stationair. Dus... motorcrossen bijvoorbeeld. Na 15 minuten is je blok ingereden, het enige waar het tegenwoordig nog om gaat is je zuigerveren en nicasil.
De rest (lagers) hoeft niet ingereden. Als je het goed doet verbruik je geen olie, en is het volledig vermogen beschikbaar. Vooral niet te bang zijn met gasgeven, mits je de toerenbegrenzer niet bereikt, en altijd goed warmdraaien.
speedphreax
Noppy schreef:Voor een crosser mag je verwachten dat je A/F ratio optimaal staat.
Nou ja, wat is optimaal? Alles wat technisch ontworpen wordt is een compromis. Het kan altijd "anders" waardoor het in een bepaald specifiek geval "beter" is. Een theoretisch optimale A/F ratio geeft trouwens niet altijd het beste resultaat (bij motoren met een slechte verbrandingsruimte bijvoorbeeld) Vaak worden ook niet alle mogelijke parameters gemeten om tot een optimaal resultaat te komen. Zit er b.v. op zo'n injectiesysteem een luchttemperatuur sensor of is dat altijd zo bij injectie? Geen idee hoor... op mijn BMW zit ie in ieder geval wel. Klopsensor is ook zoiets.
