Ervaringen ALU skid plate voor XR400
erwindob
Ik wil voor Marokko een ALU skid plate monteren onder m'n XR400
Wie heeft ervaringen met zo'n ding, al dan niet incl. watertank en gereedschapvak?
Ik ben benieuwd naar het volgende:
- merk
- prijs
- waar gekocht / besteld
- pasvorm
- stevige montage (geen klemmetjes om framebuis bv. maar gemonteerd op originele boutgaten van standaard beschermbeugel)
- stevige plaat
alvast bedankt
Rwin
Erwin,
Je zou eens kunnen kijken of Hyde een leuke skidplate voor je heeft; ze wegen 1/4 van een aluminium skidplate.
www.hydedevelopments.co.za
Alfie Cox wordt ook gesponsored door deze club, dus hun skidplates zijn wel woestijnwaardig.
Dit is een recentie van dit merk:
Hyde Developments Glide Plate
According to Wilko, I had the proto type model, Boss alloy bash plate on my DRZ 400. It had served me well and taken a hiding. DRZ 400's aren't designed to be airborne, so when the big girl comes a gutser on an erosion bank jump, the frame rails need a little protection.
I was given the opportunity to try out a Glide Plate made from High Impact Material by Hyde Developments. The web site does not detail what the glide plate is made of but it looks like a polycarbonate plastic. It is similar in looks to the black bellies found on KTM's although it is not a quick release type. To be honest I have been sceptical of these in the past. So I was curious to see how it would perform. Since black is a slimming colour and the DRZ is known to be weighty, the visual transformation was immediately gratifying. The DRZ looked like it had had liposuction. It's big silver belly was gone and in the right light with the black belly, it looks like the bike has "six pack" ab's.
Although I didn't have scales to weigh the two plates, it felt like the glide plate was a quarter the weight of the alloy bash plate.
The Hyde Developments glide plate easily bolted on with the supplied bolts. The glide plate fits around the motor very snugly. Because the space between the glide plate and the motor is so tight, washing out the mud with the pressure washer is a bit harder now.
The kit complete ready to mount.
Used and abused, the Hyde Glide Plate
seems to stand up well to punishment.
As I did with the alloy plate I might glue some rubber spacers between the frame rails and the glide plate to give it room to flex before dinting the rails on a high impact. The rubber spacers also allow the dirt to be washed out and not build up behind the rails. The glide plate already has some scars on it, so now it matches the rest of the bike. The Hyde glide plate has only been on for one ride through very rocky terrain and coped quite well.
I anticipate it will have a long and abusive future.
For model availability click on the Hyde Developments link below, RRP is $139.95 (Australian Dollars)
Reviewed by: Colin Maegher aka Capt. Nemo
Grx,
erwindob
Ze hebben wel zo'n ding maar hoe groot is de kans dat die ook echt hier is voor ik em nodig heb?
't rijden moet natuurlijk wel spannender zijn dan het wachten op bestellingen :D
Jij had toch al contact met ze gehad? Wat denk je, valt zoiets over te laten komen (1 stuks)? Hij is trouwens best duur, of is zo'n Aussie dollar de helft van een Amerikaanse? Dan is het weer vergelijkbaar met een ALU plaat qua prijs.
groetjes
Rwin
Komt in de buurt van de €45 dacht ik.
erwindob
Ik heb net een CRD besteld, was op voorraad en in de aanbieding (in Oostenrijk).
is er nog iemand die zo'n ding gebruikt of nieuw heeft liggen?
