Buying a DR Big
Hi guys,
can anybody out there give me some guidance, i'm buying my first DR Big next Tuesday and would like to hear about anything which you think i should be looking for to make sure i get a decent machine.
cheers
Colin.
ranzige rooie
hello future bigger
first look at the exhaust , started rusting before it was sold for the first time . :wink:
but the real importend thing is to listen to the engine the camshaft is sometimes worn out at 45000 km
there are cases known of bigs that get a bad driveshaft bearing at 70000 km
and sometimes the front brake pistons get stuck
with the early newer types '91-'93 the fueltank can be leaking ( from '94 there is an added support rod )
everything else is like any other motorcycle
good luck
and see you in Sühl ? http://www.matthias-hess.de/anmeldung/
where every bigger should meet :lol:
hans h
